Ethernet Enables Fast Data Transfer to Modbus TCP
By Design World Staff | June 9, 2011
ETHERNET Remote I/O is an Ethernet communication gateway and backplane for the LB/FB remote I/O system. The gateway and backplane enable the remote I/O system to build a virtual bridge between traditional field instruments and Modbus TCP-based Ethernet with data transfer rates up to 100 Mb/s.
ETHERNET-Remote-I_O-pepperl-fuchs
The field signals can have an intrinsically safe connection for Div 1/Zone 0 applications. Up to 80 analog or 184 discrete signals can be controlled through a single gateway. The high transfer frequencies require LWL connections for long distances, while the copper lines are suitable for shorter distances up to 100 m.
Pepperl+Fuchs
www.pepperl-fuchs.us
Filed Under: Factory automation, I/O modules, CONNECTIVITY • fieldbuses • networks • gateways
