Fabco-Air, Inc. Releases New OEM NFPA Air Cylinder Line
By Frank Tobe | March 11, 2014
Fabco AirFabco-Air, Inc. is pleased to announce the launch of the new OEM NFPA Cylinder Line. The FCQN Series combines cost-effectiveness with proven dependability. It is a repairable NFPA Interchangeable cylinder line that is specifically designed to give consumers an economical alternative.
The product line is loaded with standard features. In fact, the cylinders automatically come with magnetic pistons for position sensing. Adjustable cushions at both ends of the cylinders are included as a standard option as well. Stainless steel tie-rods are incorporated into the cylinder construction as well as anodized end caps.
Each cylinder includes both bottom tapped and end-cap sleeve nut mounting configuration. NFPA mounting is made easy by simply adding one of the many detachable NFPA mounts that is offered by Fabco-Air to the standard cylinder.
This air cylinder line offers elasticity to tight budgets without sacrificing quality. Additionally, with most components in stock, the new OEM NFPA is capable of meeting even the most demanding delivery requirements.
Fabco-Air
www.fabco-air.com
Pneumatic Tips
Filed Under: Pneumatic equipment + components
Tagged With: fabcoair
