A new series of split type flanged sleeve bearings from Quality Bearings & Components- QBC have a composite liner that consists of a carbon steel backing, an intermediate layer of sintered bronze, PTFE, and a lead sliding lining. These bearings are identified as the BSNFLNMMB… Series in metric and BSNFLN… Series in inch. They are designed to fit shafts ranging from 6 mm to 45 mm in diameters and .3750 in. to 1.7500 in. The overall diameter of the flanges range from 12 mm to 58 mm in metric and from .6875 in. to 2.3750 in. Quotes plus online orders are available at the new QBC eStore.
QBC has in stock: miniature bearings, plastic bearings, rod end bearings, spherical bearings, pillow blocks, sintered bronze bushings, radial ball bearings, thrust bearings & washers, sleeve bearings, needle bearings, inner races, roller clutches, guide wheels & rail systems, linear ball bearings, inner and outer ring spacers and shafting. QBC stocks both inch and metric sizes. Our eStore allows you to check price and availability, place an order or request a quote anytime. QBC also provides custom-made bearings and shafting to the customer print. We also offer on-site relubing of bearings in a certified class 1000 clean room.
www.qbcbearings.com
Filed Under: Bearings, Motion control • motor controls
