    • Subscribe!
Flatten Your Control Architecture
By Design World Staff | July 17, 2009
StationPortal‚â„¢ provides a common Ethernet interface for typically disparate I/O such as pushbuttons, bar-code scanners, LEDs, and torque guns. The architecture provides the power and flexibility of a central, server-based configuration. With it, you can eliminate PLC-based assembly support systems.
Each unit has three discrete inputs, three discrete outputs, three colored lamps, one pushbutton, one horn, and one serial port. Each of these data points is mapped directly into CIMPLICITY.
GE Fanuc Intelligent Platforms
www.gefanuc.com/stationportal
Filed Under: Networks • connectivity • fieldbuses
Softing introduces OPC UA-based OT/IT integration solution with MQTT connection
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
    • Subscribe!
