Flexible & Simplified High-Frequency Charging Solution
By WDD Staff | May 2, 2014
EnerSys (Reading, PA) [NYSE: ENS] has exhibited its extensive line of motive power solutions for manufacturing and supply chain management applications at MODEX 2014. EnForcer IMPAQ high-frequency modular chargers offer intelligent charging with advanced efficiency and the flexibility to maintain peak efficiency at all times. Modules can be automatically switched on and off based on the charge cycle requirements, and should a module develop a minor fault, the charger bypasses the module for continued operation and continuation of the charging process.
Additional featured EnerSys products at MODEX 2014 include:
  • IRONCLAD batteries with a unique square tube design that provides up to 30% more capacity than similarly sized conventional batteries.
  • NexSys battery and charger systems, optimized for cycling and long-life with rapid charging to enable high-rate fast charging during idle times.
  • Express batteries and chargers that can eliminate battery changes, battery changing rooms and changing equipment.
  • General Battery with flat plate design for high quality and dependability at optimum value.
For more information, visit www.enersys.com.
