Flexible waveguides are available from Servometer, LLC to transmit signals of microwave and radar instrumentation. By using electroforming technology, waveguides are available with the perfect combination of all-metal construction, precise internal dimensions, and flexibility.
Electroforming is the process of machining an aluminum or stainless steel mandrel, plating the external surface with metal such as nickel, copper, gold, or silver, and chemically removing the original mandrel. Because the internal dimensions of the electroform are based on the external dimensions of the machining, waveguides can be manufactured with extremely tight tolerances. With the flexibility of a bellows, electroformed waveguides can be installed in confined areas rather easily. Assemblies are available in completely custom sizes from micro-miniature structures to over sixteen feet in length. Servometer waveguides are used in land-based equipment as well as satellite communication systems. Every waveguide is constructed to operate at cryogenic temperatures.
Value added services are available as well. Servometer can solder or weld end components for seamless integration into customer assemblies.
Servometer
http://www.servometer.com/
