Significant heat removal from servomotor and gearbox combinations is now achievable with the alphaCool™ Adapter. The adapter plate connects the servomotor to the gearbox and allows maximum flow of fluid to better remove heat. In application, this water-cooled adapter can reduce output-bearing temperature by 50% as compared to the natural convective cooling.
WITTENSTEIN
www.wittenstein-us.com
Filed Under: Automation components, Gears • gearheads • speed reducers, Motion control • motor controls, Motors • servo
