GAM Selection Guide Features Bellows Couplings
By Design World Staff | July 30, 2008
GAM’s complete line of bellows couplings for servo applications are among the products detailed in a new full-line brochure from GAM. An easy-to-follow product selection chart, also available at www.gamweb.com, guides users through bore and torque ranges, hub style, bellows connection method and other major features for each series in the product line.
Select couplings offer several unique features. GAM’s patented EASY Clamp System prevents damage to hubs and allows easy shaft mounting/dismounting while compensating for tolerance differences between shaft and hub. The patented brass wire press-fit method of connecting the multi-layered bellow to the hub can withstand high-temperature and harsh chemical environments where glued connections cannot. The micro plasma weld connection offers even heat distribution which results in a long-lasting connection between hub and bellow and is ideal for high temperature applications.
GAM’s bellows couplings are available with torque ratings from 0.44 Nm to 44,000 Nm for use with servo motors. All feature high torsional rigidity, low inertia, zero backlash and misalignment compensation. They can be used maintenance-free at temperatures up to 570°F without any limitations and at speeds up to 25,000 RPM without additional balancing.
www.gamweb.com
Filed Under: Bellows, Couplings, Motion control • motor controls
Tagged With: gam
Automation 1 Family and iXC4e
49503-ACS Motion-CMxa
SDP-SI-040
