The DNR-6-1G 6-slot, portable, Ethernet I/O chassis is a smaller version of the DNR-12-1G RACKtangle‚â„¢ 12-slot front-access 3U chassis. It offers all the features of the 12-slot model in a half-rack-width configuration.
As the DNR-6-1G is electrically compatible with the ‚“Cube‚†form factors, all of the I/O boards available in the cube form factor are also available for the DNR-6-1G . With over 30 I/O modules available, there will be a configuration ideally suited for almost any application requirement. The HalfRACK‚’s 6 I/O slots provide up to: 150 analog inputs, 192 analog outputs, 288 digital I/O, 48 counter or quadrature channels, 72 ARINC-429 channels and/or 24 Serial or CAN-bus ports.
Software for the DNR-6-1G is provided in the UEIDAQ Framework, which supports popular programming and operating systems such as Windows, Vista, Linux and most real-time operating systems (e.g., QNX, RTX, RT Linux). In addition, the board is fully supported by LabVIEW, MATLAB/Simulink, DASYLab, or any application that supports ActiveX, OPC or Modbus TCP control.
United Electronic Industries UEI
www.ueidaq.com/HalfRACK
Filed Under: I/O modules, ELECTRONICS • ELECTRICAL
