Handheld Feedback System Tester Speeds Diagnostics to Reduce Downtime
By Stacy Combest | August 26, 2013
The Feedback System Tester (FST) was designed to quickly and easily diagnose Quadrature Output sensors and sensor cabling problems in Industrial Motion Control Systems reducing valuable time and cost associated with the unnecessary replacement of good sensors. The FST consists of two individual test modes.  The cable or harnessing test mode conducts 50 discrete tests to diagnose open and shorted circuits within the cable harness while testing the power supply under load. The sensor test mode powers the sensor and conducts 27 discrete performance measurements.  The sensor test mode includes both a static (motionless) and dynamic (sensor in motion) modes to accurately assess the sensors’ performance and viability.
With its rugged design, the FST is designed to hold up in challenging industrial environments. The unit’s housing is created from a light-weight, weather resistant polycarbonate material. The diagnostic tool is self-contained and includes controls, easy to use LED go/no-go display electronics, and batteries.
Industrial Technology Solutions
www.itsyoursolution.biz
The post Handheld Feedback System Tester Speeds Diagnostics to Reduce Downtime appeared first on Test & Measurement Tips.
Tagged With: industrialtechnologysolutions
eBay
When to buy used test equipment
TRACO Power now sells cost-optimized 1-A POL converters with 6-to-36-V input range
eye diagram
Simpler debugging for Automotive Ethernet systems
E+H-Prosonic-flowmeter
Flowmeter for industrial water, feedwater, cooling water and condensate
