    • On the Floor
Harwin strengthens custom cable assembly resources
By Redding Traiger | March 7, 2023
To attend to the rapidly rising demand being witnessed in the market, Harwin has significantly expanded the scope of its custom cable assembly capabilities. This service from the company’s newly announced HRi business unit covers multiple configurations and features, specifying cables to any length.
The Harwin HRi high-reliability interconnect products for which custom cabling can be provided include the company’s 1.25mm-pitch Gecko, 2mm-pitch Datamate, 3mm-pitch M300, and high-power Kona families, as well as the Mix-Tek combined power and data connectors. Among the numerous applications where they will be used are robotics, UAVs, AGVs, satellites, and medical equipment.
Large Datamate L-tek cable assemblies
When looking to source custom cable assemblies for their designs, at the moment, OEMs only have a limited number of possibilities. They can go to an assembly house, but that will call for a large upfront payment – for tooling, etc. It can often prove uneconomical, especially if there are only relatively small unit quantities required. The OEM could instead choose to do the work itself. This, however, requires investment in specialist assembly equipment, as well as extensive staff training, reorganizing workflows, etc. Then there will be the testing that needs to be conducted, which will further add to the cost and logistical complexities involved.
By engaging with Harwin, all this may be avoided. Thanks to the Harwin team’s engineering expertise, even the most challenging cabling projects can be addressed. They have the skills necessary for coax cabling work, as well as the use of twisted pairs and the addition of shield braiding to combat EMI issues. Backpotting can also be incorporated into assemblies to achieve better cable retention.
Large Datamate Gecko SL backshell connectors for rear-panel mounting
With very small minimum order quantities (MOQs) being catered for, Harwin’s custom cable offering is suitable for early-stage prototyping work. It also fully supports customers across the rest of their product’s lifecycles, including the transition into production phases.
Medium Kona male cables
Drawing on the knowledge of Harwin’s engineering professionals, the cabling implemented will deliver the maximum possible performance while still keeping the overall size and weight down. This can be very important in situations where it is necessary to consider severe constraints. Once assembled, thorough testing is carried out on the cabling to assure its quality and long-term reliability. The company’s cable assembly facility is fully compliant with the IPC-A-620 standard.
For more information about Harwin’s cable assembly capabilities, visit: https://www.harwin.com/cable-assemblies
Tagged With: harwin
    • On the Floor
