ComInTec’s GD gear couplings are flexible shaft connections for positive-locking torque transmission and particularly suitable for compensating for axial, radial, and angular shaft displacements. Our gear couplings are also dimensionally drop-ins for many expensive German couplings.
Nylon-steel-combination
Axial plug-in, easy assembly
Torques up to 2,500 Nm (22,000 in-lbs)
very good ability for electrical insulation
good resistance to lubricants and hydraulic fluids
high mechanical strength of polyamide material
good dimensional accuracy
Suitable for both low and high temp applications
Maximum Bore Diameter: 125 mm (5”)
TYPICAL APPLICATIONS: Pumps, Water and Fluid Processing Equipment, Custom Machinery, Packaging Machinery, Fans, Turbo Compressors, Vertical Pumps, Cooling Towers, Printing Machinery, Paper Machine.
Hexelus
www.hexelus.com
Filed Under: Coupling Tips
