Santa Ana, CA – In response to customer requests, a heavy duty version of the Slimline Kinechek ,the “High Capacity” Model Kinechek is being offered for applications in excess of 1200 lbs. force. The leak proof Kinechek High Capacity Speed Regulator can handle the toughest jobs, enabling loads of up to 2400 lbs. force to be controlled. (Including impact when load strikes plunger)
The High Capacity Kinechek packs substantial load handling capacity into a reasonably sized unit. Tip to Tip, the unit measures 17 inches with a 1.25 inch diameter body. The plunger rod measures ½ inch in diameter and is hardened on end for long wear life. This model is available in a 2 inch or 3 inch stroke unit.
The High capacity Kinechek is essential when the load exceeds the capacity of the original Slimline version of the Kinechek.
High Capacity Kinecheks have been used extensively to control all types of robotics, milling operations, packaging machines and food processing equipment.
High Capacity Kinecheks offer the same patented, leak proof performance and high quality construction features as the original SLIMLINE Kinecheks: The ID of the hardened tool steel high pressure cylinder with an adjustable flow control passage is mirror finished and mated to an all metal piston with no sliding seals. This design makes the plunger rod on all kinecheks move smoothly at a constant rate throughout the entire stroke.
High Capacity Kinecheks are part of an extensive line of Kinechek model speed regulators and offer the same patented, leak proof performance as the original Slimline Kinecheks.
Downloadable PDF files containing High Capacity Kinechek specifications can also be accessed from the Deschner website.
Deschner Corporation
www.deschner.com
Filed Under: Automation components, Packaging, Fluid power, Shocks + vibration control • gas springs
