An important factor to consider in the design of an electronic enclosure is its ability to prevent unwanted interference from seeping into the surrounding environment. Leader Tech (Tampa, FL) beryllium-copper fingerstock gaskets are an ideal choice for making reliable electrical contact between parallel seams (mating surfaces) that are created by enclosure access doors and panels. These high-performance, hardened Alloy 25 gaskets:
- Are available in hundreds of easy-to-install styles and sizes to accommodate thousands of enclosure applications.
- Exhibit excellent shielding effectiveness over a broad frequency range.
- Feature high tensile strength and resiliency.
- Can withstand repeated compressions that are encountered when opening and closing an enclosure door.
For more information visit http://www.leadertechinc.com.
