High Performance Stepper Drives
By Design World Staff | February 21, 2007
WATSONVILLE, CA — Applied Motion Products family of STAC6 High Performance Stepper Drives are now available in 220 VAC models.  These drives offer advanced features to provide absolute maximum performance benefits from a stepper motor, and provide software selectable resolutions from 200 to 51,200 steps/rev at speeds up to 50 rps.
Self-Test and Auto Setup features measure and configure motor parameters automatically, while anti-resonance technology eliminates midrange instability for higher motor speeds and fuller use of available torque.  Demand Signal Smoothing reduces extraneous system resonances for smoother motor performance and reduced wear on mechanical components.  Torque Ripple Smoothing adjusts the current waveform to reduce low speed torque ripple for smooth motion at low motor speeds.  Additionally, MicroStep Emulation provides smooth motion for systems that require low step resolutions, such as retrofit systems with controller resolution that is fixed at a low value and cannot easily be changed.
Two integral control options are available, including an intuitive graphical programming language as well as a comprehensive high-level language for precise control of all drive features.  Setup and configuration is also made easy with graphical, intuitive CONFIGURATOR software.  The drive can be configured from a drop-down menu, or the user can quickly create custom motor configurations if desired.
In applications requiring an encoder, the STAC6 offers additional benefits.  These include Stall Detect that can trigger a fault output when a motor has not reached its programmed position, Position Maintenance to hold the motor position firm even when external forces are trying to move it out of position, and Stall Prevention where the drive will work to end the desired move with new parameters.
Founded in 1978, Applied Motion Products specializes in cost-effective, high precision motors and motion control solutions.  They offer a full complement of stepper and Brushless servo motors, positioning control electronics and gearheads to industrial and OEM customers.
For more information contact: Applied Motion Products, 404 Westridge Drive, Watsonville, CA 95076; 1-800-525-1609; fax: (831) 761-6544; E-mail: [email protected]; Web site: www.applied-motion.com.
:: Design World ::
Filed Under: Medical-device manufacture, Drives (servo) + amplifiers, Drives (stepper) + amplifiers, Packaging, Motion control • motor controls
