    • Subscribe!
HPB Connectors from FasTest
By Patrick Curran | May 26, 2010
Minneapolis, MN — FasTest announces the expanded line of FasCal High Pressure Ball (HPB) series connectors. Sleeve-actuated HPB connectors provide fast, safe and repeatable connections to 1/4″ to 1/2″ male NPT, -4 to -8 AN and -4 to -8 compression threads, allowing users to simply calibrate numerous instruments in a short period of time.
FasTest-FasCal-HPB-Series-Connectors
A connection is formed by simply pushing the sleeve onto the fitting, eliminating strenuous twisting and turning. The connector is released by pulling the sleeve away from the connection. The patented pressure-assisted, grip-and-seal technology creates leak-tight connections and eliminates thread damage that typically results from the use of sealants and wrenches. The push-to-connect action allows fast transitions from one transmitter to the next and is shown to allow five times greater calibration efficiency.
HPB series connectors are rated at 5,000 psi, and include a safety feature to prevent disconnect under pressure. Connectors feature stainless steel construction for increased durability and corrosion resistance in a wide range of environments.
FasTest
www.fastestinc.com
Filed Under: Connectors (electrical) • crimp technologies, Fastening + joining • locks • latches • pins
molex-versablade-300x300
Heilind Electronics now offering Molex VersaBlade Wire-to-Wire Connector System
bel-stewart-m12xcode-connector
Stewart Connector M12 X-Code PCB mount connectors
Heilind-electronics-product-image
Heilind Electronics now offering Molex PowerPlane BusBar Power Connectors
Harting Technology Group heads for a climate-neutral future with record investment
    • Subscribe!
