Hybrid cable grommet simplifies cable entry for hybrid connectors
By Mary Gannon | March 11, 2019
icotek_KT-M hybrid cable grommetWith the new KT-M cable grommet from icotek, the built-in plugs and installation jacks are integrated directly into the icotek cable entry strips KEL, KEL-U or KEL-ER.
The KT-M is ideal for interfacing to signal, data, power or hybrid connectors by simply screwing them into the threads of the KT-M. Even hose fittings or pressure compensation elements can be easily screwed to the KT-M.
The grommet KT-M is built on the basis of a large KT cable grommet. In this grommet, a polyamide body is integrated. The KT-M is available with inner threads of M12x1.0, M16x1.5, M20x1.5 and M25x1.5. Alternatively, the blind grommet KT-M is available for special solutions. The integrated polyamide body is completely closed on one side. The effective area is 24 x 24 mm, the wall thickness is 6 mm. Special bores can be made or smaller flange bushes (for example for hybrid device connectors) can be attached.
icotek
www.icotek.com
Filed Under: Cables + cable management, Connectors (electrical) • crimp technologies
Tagged With: icotek
molex-versablade-300x300
Heilind Electronics now offering Molex VersaBlade Wire-to-Wire Connector System
bel-stewart-m12xcode-connector
Stewart Connector M12 X-Code PCB mount connectors
Heilind-electronics-product-image
Heilind Electronics now offering Molex PowerPlane BusBar Power Connectors
Harting Technology Group heads for a climate-neutral future with record investment
