Sunnyvale, CA — IDEC Corporation offers the first and only 4-point universal analog input module, expanding the already impressive capabilities of the fastest micro PLC on the market, the MicroSmart Pentra. This high-performance module accepts most analog signals including 0-10V, 4-20mA, thermocouple (type J, K, T), RTD (Pt 100/1000) and Nickel (Ni 100/1000). Each channel is independent and can be configured to accept most analog input devices.
MicroSmart Pentra provides high-level control functions and a universal analog module that solves analog control needs. This IDEC module has 16-bit resolution, 0.2% accuracy, and fast conversion times. Plus this universal analog module expands the MicroSmart Pentra’s ability to handle applications that require more analog I/O. Easily snap the new module to the side of the MicroSmart Pentra and stand back to enjoy greater system throughput at a competitive price. With a fast Logic Engine and standard features including double word & floating math, Modbus RTU/ASCII, a recently released Modbus TCP/IP, upgradeable firmware, embedded 100kHz high speed inputs and outputs, up to 7 communication ports and easy-to-use software, the MicroSmart Pentra has it all.
Filed Under: I/O modules, ELECTRONICS • ELECTRICAL
