In the Black: WAGO 2060 Series
By Editor | November 9, 2012
A new, black housing for WAGO Corporation’s 2060 Series SMD Push-Button Terminal Block helps ensure correct LED device wiring. Offered as a 1-pole unit (2- and 3-pole upon request), the black housing provides on-board + and – color-coding when paired with light gray 2060 Series blocks. Beyond clear inputs/outputs, the new block also offers WAGO-exclusive push-button terminations to streamline LED device assembly, e.g., downlights.
The new housing also supports higher-temp applications, such as high-output, outdoor LED fixtures for roadway and stadium lighting. The black 2060 Series features the same ratings as its UL/cUL Recognized siblings 600 V (1-pole), 250 V (2- and 3-pole) and 9 A nominal current (all models).
WAGO
About 2060 Series:
2060 Series™ push-button terminations are a laborsaving alternative to hand-soldering PCB leads. Push buttons also permit wiring error correction no costly scrap/rewiring. 2060 Series accommodates the broadest range of solid/stranded conductors (AWG 24“18) within one unit even tinned, top-coated or pre-bonded ones.
LED applications include: recessed luminaires, emergency lighting and signage. Just 4.5mm high, 2060 Series also serves electronics requiring low-profile SMT components, such as alarms and HVAC controls.
WAGO Corporation
www.wago.us
Filed Under: Terminal blocks
Tagged With: WAGO Corporation
MLTB Press Release Image
New multi-level terminal blocks from Wago
Multi-level terminal blocks provide space savings & functionality
jumpers-product-image
WAGO provides an alternate to standard jumpers
TJS 12 AWG Square
New TOPJOB S Mini Terminal Blocks increases wire sizing
