    • On the Floor
Interpower’s 1725VA Power Source
By Natasha Townsend | November 19, 2012
Interpower Corporation (IPS) previously named Panel Components Corporation; was founded in Berkeley, California by Bob Wersen in July 1975. Headquartered in Oskaloosa, IA, it has a low-cost, convenient source of ac power, which users may test their product before exporting globally. Common operating voltages and frequencies for global electrical products are typically 110-240 V ac, 50-60 Hz. This power source provides fast, convenient testing of ac electrical equipment at those common operating voltages and frequencies.
A great feature provided by the power source are seven of the most common country specific ac receptacles ensuring that equipment under test utilizes the proper ac plug. Testing electrical products with the power source during product design stages or in production test prior to export assures that the global product will perform when received. The unit can also be used to simulate brownouts, or drops in voltage in an electrical system.
This unit offers output power at 1725 VA maximum, low range variable at 10-138 V ac at 12.5 A ms maximum and a high range variable 10-276 V ac at 6.25 A ms maximum, 47-450 Hz.
With over four million products in stock, IPS offers a 1-week lead-time on any manufactured product, with no minimum order requirements, while specification sheets and pricing are available online.
Same day air shipments are available for stock item orders received by 6:00 p.m. CST.
www.interpower.com
Power Supply Tips
Filed Under: Hose • wraps + sleeves, Power Electronic Tips
Tagged With: interpowercorporation
  • Agentic Requirements Engineering: Reduce Friction in Requirements Workflows
  • Five trends in automation for the second half of 2026
    • On the Floor
