IO-Link Master Block insulates against noise, protects in harsh environments
By PR Editor | September 3, 2019
Balluff’s EtherNet/IP IO-Link master block insulates against inductive, conductive, and capacitive noise produced by electromagnetic interference (EMI). And its robust housing protects against harsh welding environments.
This IO-Link master block:
• reduces inductive noise using coil choke filters
• reduces conductive noise with its fiberglass-reinforced, polyphenylene sulfide (PPS) housing
• reduces capacitive noise with its thick profile, which raises the printed circuit board away from the backplane
This master block was designed to protect against electromagnetic interference that can negatively impact work processes. The non-conductive PPS housing does the work of a separate grounding plate. And PPS is also inherently non-stick, so weld spatter slides off it. The BNI00CY IO-Link master block’s built-in display allows configuring of network parameters, and its embedded web server allows for remotely configuring the block and connected IO-Link devices.
This master block offers four Class A IO-Link ports and four Class B IO-Link ports.
Key features include:
•Filters multiple types of EMI
•PPS composite body resists weld spatter
•4x Class A, 4x Class B IO-Link master ports
•Built-in enhanced web server, and display for configuring network parameters
•Up to 9A of output power with 2A per channel
Balluff
www.balluff.com
Filed Under: TECHNOLOGIES + PRODUCTS, Factory automation, I/O modules, IoT • IIoT • internet of things • Industry 4.0
Tagged With: balluff
DRP - Line
Andantex will introduce a new planetary reducer design concept at IMTS
Custom pneumatic conveyors for unique applications
Advantech-iDAQ-3
Advantech launches iDAQ modular DAQ
CC100 product image_1
WAGO combines PLC and remote I/O into compact controller
