Ashcroft’s Model DM61 digital panel meter does more than merely display an analog or Modbus RTU digital signal from a sensing device with an output. Instead, equipped with a variety of electronic features, this input-output device allows the user to configure the display to readout in their required engineering unit. Engineers can have the device recall minimum and maximum readings, as well as set high/low alarms.
Standard features include a six digit display, password protection and an on-board DC transducer power supply. Also available are internal or external relays, a 4-20mA output and expansion modules to enable conversion to USB and other serial outputs.
Ashcroft Inc.
www.ashcroft.com
Filed Under: Design World articles, Sensors (position + other)
