IoT wireless I/O module
By Frank Tobe | May 25, 2016
AdvantechThe WISE-4012 wireless Ethernet I/O module can be used without a gateway. Deployment is easy due to a limitless number of I/O modules that can gather data from any third party analog sensor and connect to an existing network.
With integrated analog and digital input in the same channel, this module provides a flexible combination of I/O to acquire different kinds of signals. It can also send out the engineering or physical value as sensor input using a scaling function, which makes the data more readable for further analysis. The WISE-4012 has high resolution, high accuracy and isolation protection so it can provide quality data for smart factories and smart city data acquisition solutions.
The WISE-4000 Data Logger can send time-stamped information to a Dropbox account or a private cloud and buffer device data so that should the network fail, no data are lost before transmitting to the administrator.
Advantech Corporation, Industrial Automation Group
www.advantech.com/ea
Filed Under: IoT • IIoT • internet of things • Industry 4.0, Networks • connectivity • fieldbuses
Tagged With: advantech
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
