ERIE, PA — Innovative Pressure Technologies (IPT) introduces High Pressure Tubing. Made of 316L Stainless Steel as standard, this quality tubing is available in a wide variety of sizes and grades to satisfy specific application needs, and is highly resistant to corrosion. This tubing provides good resistance to organic acids at high concentrations and moderate temperatures, to inorganic acids (e.g. phosphoric and sulphuric) at moderate concentrations and temperatures, to salt solutions (e.g. sulphates, sulphides and sulphites), and in caustic environments. 316L tubing can be used in sulphuric acid concentrations even above 90% at low temperature.
IPT’s High Pressure Tubing is rated for use in temperatures from -100° to 600°F (-73° to 315°C), with maximum working pressure of 20,000 PSI (1030 bar) or 60,000 PSI (4140 bar). Tubing is supplied in 18-22 ft. lengths, with custom lengths available upon request.
This tubing is well suited for use in industrial applications where types AISI 304 and 304L provide insufficient corrosion resistance. Typical applications include heat exchangers, condensers, pipelines, cooling and heating coils, as well as applications in the offshore oil and gas, chemical, petrochemical, pulp and paper, and food industries.
www.inpressure.com
Filed Under: Fluid power, Tubing components
