Iron Phosphate Battery Presents as a Sealed Lead Acid Battery Replacement
By atesmeh | January 25, 2011
Micro Power announced IronWorks, an Iron Phosphate battery solution, which serves as a drop-in replacement for Sealed Lead Acid (SLA) batteries. This new standard U1 format battery intended for use with mobile equipment offers light weight, long runtime, fast charge time and long cycle life. IronWorks is based on Lithium Iron Phosphate. The battery features thousands of cycles with full 100 percent discharge, zero maintenance for several years; and fuel gauging and battery status are reported via standard SMBus. They accept SLA charge regimens and tout a robust mechanical design.
Micro Power
800-576-6177, www.micro-power.com
Click on the links below for more information:
Ironworks brochure
Ironworks datasheet
