JW Winco introduces inch set screws steel, with brass or nylon tip
By Mike Santora | December 5, 2018
JW-Winco-inch-set-screwJW Winco, Inc., A Ganter Company, a supplier of standard industrial machine components, has recently introduced WN-913.3 Inch Size Steel Set Screws, with Brass or Nylon Tip.
These set screws, with a black oxide finish, are used primarily in applications where you want to avoid the marring of a shaft or damaging a soft piece of material, but still need to secure it in place with the brass or nylon tipped set screw. They can be used with a variety of different parts, including levers, hand knobs, star knobs, and knurled nuts.
“Those that operate in the area of machine building, including medical, packaging, and pharmaceutical, and material machining would find these set screws work very well for applications within these industries,” said John Winkler, CEO, Office of the President at JW Winco.
JW Winco is a manufacturer/distributor of inch and metric standard parts. JW Winco offers an extensive selection of plastic, steel and stainless steel adjustable levers, cabinet U-handles, hinges and locking mechanisms, revolving and retractable handles, hand wheels, hand cranks, tube connection and conveyor components, construction tubing, shock absorption mounts, leveling mounts, hand knobs, spring, ball and indexing plungers, jig, fixture and fastening components, retaining magnet assemblies, toggle clamps, casters and wheels, universal joints, oil sight glasses, and metric tools for the industrial and commercial equipment industries.
JW Winco
www.jwwinco.com
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES, Fastening + joining • locks • latches • pins
Tagged With: jwwinco
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
