The Kindorf® Trap-Eze™ Connector from Thomas & Betts allows new trapeze sections to be installed directly above, or to the side of, an existing assembly without disturbing the original unit – significantly reducing trapeze retro-fit time. Used as a system, the Kindorf Trap-Eze Connector and Kindorf® Trapnut® Strut Fastener delivers, on average, 43 percent time savings on retro-fit trapeze applications compared to standard trapeze systems using nuts and washers.
Kindorf Trap-Eze Connectors are designed for use with various lengths of strut that can vary by as much as an inch, and incorporate a unique visual guide or view window that allows a safety zone for strut length. This allows rough cutting of struts rather than precise cutting as required with other strut systems. The Kindorf Trap-Eze Connectors are reusable, and include a unique safety slot designed to prevent disengagement of the trapeze system, while maintaining the bracket position on either a 3/8- or ½-inch threaded rod.
Thomas & Betts
www.tnb.com
Filed Under: Fastening + joining, ASSEMBLY, Connectors (electrical) • crimp technologies
