Klϋber Lubrication, a worldwide manufacturer of specialty lubricants, introduces Klübersynth GE 14-151, a special grease for highly loaded small gears like those found in power tools.
This product consists of a finely balanced combination of ester and synthetic hydrocarbon base oils with an aluminum complex soap thickener. Klübersynth GE 14-151 has a wide service temperature range, good wear protection properties and a high scuffing load capacity. It also offers high protection against tribocorrosion.
Klübersynth GE 14-151 can be used to lubricate toothed wheels, bearings, joints and slideways. The optimized oil release behavior enables use in applications that are not sealed oil tight. With a high scuffing load capacity and good backflow behavior, the grease allows lubrication of gears with a high sliding ratio.
Depending on temperature, load and sliding speed, Klübersynth GE 14-151 can even be used on steel-steel, steel-aluminum, and aluminum-aluminum components. When used for lubricating trapezoidal and ball-and-screw spindles, it offers excellent wear protection and smooth running.
Klübersynth GE 14-151 can be used in gears operating at peripheral speeds of approximately 10 m/sec with a quasi-complete fill of the gear housing. It can maintain speeds of 20 m/sec over short-term or intermittent operation. Tooth flank lubrication allows a speed of 3 m/sec.
Klüber Lubrication is a manufacturer of specialty lubricants and high-end tribological solutions. Most products are developed and made to specific customer requirements. During its more than 80 years of existence, Klüber Lubrication has provided high-quality lubricants, thorough consultation and extensive services, which has earned it an excellent reputation in the market. The company holds all common industrial certifications and operates a test bay hardly rivalled in the lubricants industry. For more information, visit klueber.com.
Freudenberg Chemical Specialities Munich, was founded in 2004 as a new Business Group within the Freudenberg Group. Its objective is to promote innovation potentials in its field of activities and to expand world-wide market leadership in special lubricants and release agents. The Business Group includes five largely independent divisions which are active in more than 50 countries: Klüber Lubrication, Chem-Trend, SurTec, Capol and OKS.
