Kollmorgen Introduces AKM™ 8 Servomotors
By Miles Budimir | January 12, 2011
Kollmorgen introduces AKM™ 8 Servomotors – the latest addition to the company’s AKM motor series. With a feature-set to satisfy global requirements right from the base hardware, AKM8 motors deliver higher torque density to cover the broadest torque/speed range in a housing that is 30% shorter than any standard motor in its class available today. As a result machine builders can reduce the size of their machines without sacrificing performance, or they can select a longer stack length to achieve higher performance without having to specify a larger, more expensive motor that would typically require mechanical changes to the machine.
Kollmorgen-AKM-8-Servomotors
The AKM8 is available in two standard flange/shaft combinations designed to seamlessly integrate with 80% – 90% of machine builder needs around the globe, with no modifications to the customer flange needed. As standard, AKM8 windings are designed to operate at 230, 400, 480 VAC, eliminating the need for voltage transformation for machines that will be deployed in various geographic regions. AKM8 motors feature Class F insulation for a temperature rating of 155°C, and provide stall torque from 75 to 180 Nm, operating speeds up to 2500 rpm, and power up to 19.8 KW, with bearing lifetime rated to 20,000 h. These motors are RoHS and REACH compliant, UL listed, and carry the CE mark.
All AKM series motors feature a robust one-piece housing with potted windings for maximum wire isolation and excellent heat dissipation, resulting in robust performance and long life in even the most demanding application environments. Market-standard high resolution feedback options for high- performance/precision or rugged environments are available, including Endat, BISS, Hiperface, and resolver option, among others. AKM motors are available for low or high speed (to 8000 rpm) applications, with windings that can be applied to all standard global voltages including 75 VDC, 120, 240, 400 and 480 VAC. A number of options are available to satisfy wide ranging application needs including a reinforced bearing to handle higher radial force, a sealing option to achieve IP67 protection at the flange, as well as varied connectivity and mounting options.
Kollmorgen
www.kollmorgen.com
Filed Under: Factory automation, Motion control • motor controls, Motors • servo
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
