    • Subscribe!
Large screen HMI from QSI Corporation
By Patrick Curran | March 14, 2011
The QTERM-A12 is designed and built for your most rugged applications. Industrially hardened to perform in extreme environments, the QTERM-A12 is UL listed Class I Div 2 certified and meets NEMA-4X and IP66 specifications. This rugged HMI features universal connectivity, a bright 307 mm (12.1″), 800 x 600 TFT-LCD display, resistive touch screen, Ethernet 10/100Base-T with two USB 2.0 full-speed host ports and two serial ports to connect to nearly any device. The QTERM-A12 comes loaded with your choice of iX Software for automation control or you can program directly in the Windows® Embedded CE 6.0 environment.
qterm-a12-hmi
QSI Corporation
www.qsicorp.com
Filed Under: Factory automation, Electronics • electrical, HMIs • operator interfaces • monitors
molex-premo-flex
    • Subscribe!
