The WAL-DL-60LED-M-GCR50 LED drop light from Larson Electronics offers a much longer lamp life, cooler operation, higher durability, and better light quality than incandescent drop lights. Constructed to be completely weatherproof and impact resistant, this LED drop light sacrifices no light output or quality to obtain these features. This task light features sixty LEDs arranged in rows to produce a 120 lumen floodlight pattern. An embedded rocker switch located in the handle of the task light provides easy on/off operation. The body of this drop light features two magnets, one at the tip of the light and the other located in the middle of the light.
This unique mounting capability allows the operator to temporarily mount the light anywhere a metallic surface is accessible. This unit also features a detachable hook that can be attached to either magnet, adding to the versatility of this light. Featuring a small, compact design, this hook can be hung overhead anywhere feasible. The 50’ retractable cord reel provides cable management to reduce the risk of tripping over excessive cable lying in the work place. The cord reel is designed for a lift/drag of up to 50’ of 18/2 SVT cable and has an additional 2’ for safety wrap and hook up. The slip ring enclosure is built to NEMA standards and has two conductors. It is UL listed, and is constructed of durable steel, has a white powder coat finish, and includes a ball stop and ratchet mechanism with a lockout feature.
Larson Electronics specializes in portable industrial lighting equipment, high mast light towers, explosion proof light fixtures, power distribution systems, LED lighting and more. To view their wide range of products, visit them on the web at Larsonelectronics.com or call 1-800-369-6671 for more information. Larson Electronics will be attending the 2016 OTC show in Houston, Texas from May 2nd to May 5th. Visit them at booth 6716 to inquire about their lighting solutions for many industrial applications.
Larson Electronics
larsonelectronics.com
Filed Under: Slip rings + rotary unions, Power Electronic Tips
