LED Warning Lights from Patlite for AC and DC Applications
By Stacy Combest | June 17, 2013
Patlite’s new LFH Series LED Warning Lights produce a high-visibility, 110 flashes-per-minute strobe beacon light suitable for virtually any industrial application: indoor or outdoor, day or night, rain or shine, hot or cold. The lights provide superior sunlight visibility in the daytime, and nighttime visibility of 3,280 feet (1,000 m).
These extremely compact and energy efficient LED lights are available in four operating voltages (12, 24, 48 VDC, and 90-250 VAC), making them optimal for a wide range of industrial warning light environments such as factories, utilities, food and beverage, pharmaceutical, parking lots, loading terminals and many others. DC models offer a rugged 90m/s2 (9G) vibration resistance rating ideally suited for forklifts and loaders, construction equipment, maintenance and other industrial vehicles. All models are adaptive to mount in an upright, inverted or sideways orientation. The lights have a 100 x 100 mm mounting surface footprint, and are 143.5 mm tall. The highly refractive lens covers are available in five colors (red, yellow, green, blue and clear).
The LFH Series features rugged, durable construction with low energy consumption and long service life in mind. The long life LED makes it ideal for placement in hard to service locations. For wet environments, the LFH is water resistance per IP66 (IEC606529) when installed in the upright position. DC models are rated for operation in -22 to 158°F (-30 to 70°C) ambient temperatures; AC models are rated for -4 to 140°F (-20 to 60°C). All models are engineered to meet the requirements of most industrial applications, including: CE certified, UL 1638 listed, RoHS compliant (directive EN50581), CAN/ULC-S526-M87 UL, FCC certification Part 15 Subpart B Class A), and NEMA Type 4, 4X,13.
PATLITE
www.patlite.com
Filed Under: Lights • signal lamps • indicators, ELECTRONICS • ELECTRICAL
Tagged With: Patlite
