LEDtronics All-Weather Filament-look LED String Lights run circles around the incandescent competition
By Anna Casey | March 29, 2018
LEDtronics® announces its new All-Weather, UL-Listed Filament-look LED String Lights that answer the demands for brilliant, mood-setting lighting with all the benefits of energy-efficient LED technology.
These versatile LED string lights are ideal for applications such as special outdoor occasions, garden or backyard parties, or providing a decorative flair to outdoor restaurant porches, shopping plazas, hotel pool areas, decks, driveways and patios, as well as for sign perimeter lighting.
The 48-foot, IP65-rated waterproof black string cord holds 24 1.5-watt S14 LED lamps with a bulb separation of 2 feet. It features industrial-grade outer neoprene rubber sockets that endure years of inclement weather. Industry-leading 18-gauge wiring allows connecting up to 45 strands. Steel cables can be threaded through the built-in loops above each socket to support and position the light strings in variously decorative patterns.
Securely packaged in a rugged carton, the 24 twin-filament S14 LED lamps come in a choice of warm, 2200K “filament” white or 2700K “halogen” white. They feature a clear glass lens and an E26 base, operate on 120VAC, and provide a 360° omnidirectional illumination of 150 lumens each—an efficacy of 100 lumens per watt!
The IP65-rated, moisture-resistant LED lamps boast a wide operating temperature range of -40°F to +122°F — ideal for outdoor, inclement-weather applications. Consuming only 1.5 watts each (36W total string), they offer energy savings of up to 50% over incandescent lamps, and lumen maintenance of over 70% at more than 15,000 hours.
LED lamps produce almost no heat and require 80 to 90% less operating power than equivalent incandescent bulbs, making them as friendly to the environment as they are to the operating budget. Unlike tungsten or halogen lamps, these LED lamps do not use any toxic metals and thus are RoHS compliant.
Both the S14 LED lamps and the 48-ft black neoprene string cord are UL-listed and come with a 2-year and 3-year unconditional LEDtronics warranty, respectively.
The LEDtronics All-Weather, UL-Listed, Filament-look LED String Lights are available through LEDtronics distributors, and quantity discounts are available.
For more details and technical data, visit the product family web page:
http://www.ledtronics.com/Products/product_select.aspx?id=LEDSTR4824-S14E26-XHW-120A
LEDtronics®
www.ledtronics.com
Filed Under: Lights • signal lamps • indicators, ELECTRONICS • ELECTRICAL
Tagged With: ledtronics
