Littelfuse Introduces 437 Series Surface-Mount Fuse
By Design World Staff | July 11, 2008
DES PLAINES, IL – Littelfuse, Inc. (NASDAQ/NGS:LFUS) introduces the 437 Series surface-mount 1206-size fuse for reliable DC circuit protection in electronics applications with high ambient operating temperatures. Unlike comparable fuses, the 0437 Series operates effectively in temperatures ranging from -55‚ºC up to 150‚ºC without nuisance tripping. The 437 Series ceramic fuse has a temperature rating 20 percent higher than its closest competitor, and it has the ability to respond quickly to overcurrents without nuisance tripping caused by high inrush currents.
There is a growing need for protection in electronic applications in which high ambient operating temperatures are common. For example, LCD inverters, LCD TVs, LCD monitors, notebook computers, hard disk drives, XDSL modems, set-top boxes, and gaming consoles may experience temperature extremes. The 437 Series fuse provides a robust load rating up to 6.4A2s (8A current rating), which coupled with a high nominal melting rating (l2t), enables the 0437 to operate reliably over a wide temperature range, minimizing nuisance trips during momentary overload conditions.
The 437 Series includes UL and CSA agency approval and is available in current ratings from 250mA to 8A allowing this series of fuses to be used in a variety of applications. Each fuse has a maximum fault current rating (Interrupt Rating) of 50A and is 100 percent lead-free, halide-free, and compliant with RoHS requirements.
www.littelfuse.com
Filed Under: Fuses, ELECTRONICS • ELECTRICAL
