Cooler operation stepper motor from Lin Engineering increases efficiency, lowers operating cost
By Megan Hollis | October 7, 2015
Lin Engineering introduced the G4518 Cool Operating Stepper Motor. The G4518 is designed to run up to 30% cooler than conventional motor of similar specifications. Low heat generation makes this motor ideal for applications where heat is a concern.
Lin Engineering
Cooler operation also increases efficiency, which lowers operating costs.
The G4518 is a NEMA 17 sized motor and is available in three different lengths: 1.34” (34mm), 1.58” (40mm), and 1.89” (48mm). The step angle is 1.8 degrees.
The G4518 motor provides up to 98 oz-in (0.69 N-m) of holding torque. To insure maximum torque at desired speed, winding can be customized. Custom winding service is available at no additional cost directly from Lin Engineering.
To achieve even more torque, the G4518 can be safely over-driven by up to 20%.
The G4518 Cool Operating Stepper Motor is available for immediate purchase directly from Lin Engineering. For more information visit www.LinEngineering.com, or call (408) 919-0200 for inquiries and custom orders.
Lin Engineering
www.linengineering.com
Filed Under: Motors • stepper
Tagged With: linengineering
Faulhaber-product shot
Exceptionally high speed and dynamics form Faulhaber
Oriental Motor expands PKP Series with CS Gear and 28mm High Resolution types
AZ Series drivers available with PROFINET Communication
AutomationDirect-stepper-motor
Larger stepper motors now available at AutomationDirect
