    • Subscribe!
Low-profile, high-precision motorized cross-roller linear stages from OES
By Miles Budimir | January 19, 2018
Optimal Engineering Systems, Inc. (OES) offers a high-precision series of low-cost, low-profile motorized single-axis positioning stages. The compact AQ110 Series of four cross roller linear stages have travel lengths of 15 mm (0.590 in.), 30 mm (1.181 in.), 50 mm (1.968 in.), and 75 mm (2.952 in.) Open-loop repeatability of all stages is 0.5 µm using a 10 mirco-steps-per-step step motor driver or just 0.25 µm using a 20 mirco-steps-per-step step motor driver. Precision ground lead screws with just 2 µm of backlash and high precision cross roller linear travel guides assures repeatability of 5 µm, and positional accuracy of 10 µm.
stages
Table sizes and loads of these linear stages are: AQ110-15 is 65 mm x 65 mm (2.559 in. x 2.559 in.) and 10 kg (22 lb), AQ110-30 is 90 mm x 90 mm (3.543 in. x 3.543 in.) and 15 kg (33 lb), AQ110-50 is 90 mm x 110 mm (3.543 in. x 4.331 in.) and 15 kg (33 lb), and the AQ110-75 is 90 mm x 110 mm (3.543 in. x 4.331 in.) and 20 kg (44 lb). Each of the tables has a pattern of 16 threaded mounting holes for the addition of custom tooling and the base has drilled and countersunk holes, for easy integration into new and existing applications.
There is a knob on the back of the motor for manual adjustments or it can be replaced with an incremental encoder. Options include: servomotors, encoders, limit switches, and fully compatible multi-axis motion controllers. Additionally, any of AQ110 series of linear positioning stages can be ordered as a complete plug-and-play system.
Longer travel can be accommodated as well by consult with the company’s team of linear motion specialists.
For more information, visit www.oesincorp.com.
Tagged With: linear stage
Elevator stages feature 0.03 micron resolution
igus offers custom toothed belt pulleys delivered in 48 hours
Enhancements to Thomson online ball screw configuration tool simplify selection and ordering
Beckhoff optimizes linear motion with machine learning solution that eliminates cogging
    • Subscribe!
