SOUTHCO, a leader in engineered access hardware has introduced the latest product in its successful line of magnetic catches, with a new version that combines strength and style. Constructed of corrosion resistant stainless steel, the M5 Magnetic Catch combines a highly polished finish with the holding power of rare earth magnets to provide a robust and attractive solution for keeping doors and panels open or closed.
Southco’s M5 Magnetic Catches provide a reliable alternative to door stays, are well-suited to high vibration environments, and can be configured to provide nominal holding powers from 50-118 N (11-26 lbs) to accommodate multiple door sizes and weights with a significant tolerance for misalignment. With simple push-to-close and pull-to-open functionality, and a stylish high-gloss, stainless steel appearance, M5 Magnetic Catches offer an attractive solution for cabinets and doors in a variety of applications.
M5 Magnetic Catches are available in a range of swivel catch height options that can be mounted horizontally or vertically, and fixed catch options that mount flush to or directly on the surface to suit a wide range of door, panel and window dimensions. Swivel catches are easily adjusted to hold at any desired angle and include a rubber bumper surface to minimize noise from closing and vibration, while preventing scratching of the mating fixed catch.
According to Global Product Manager Cindy Bart: “Styled to complement applications including RV, rail, bus and marine equipment, Southco’s M5 Magnetic Catches provide the strength necessary to keep doors and panels in place with a range of configurations for flexible mounting and alignment. With its highly polished, stainless steel construction, the M5 offers exceptional corrosion resistance for challenging environments.”
Southco
www.southco.com/M5-7
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES
