IHR Series High Power Ring Lights from LDDLIGHT.com are designed for applications requiring high light intensity, illumination of large areas or long working distances. The company asserts its IHRs are equipped with Power LEDs that provide significantly higher output when compared to more conventional LED ring lights. The high illumination intensity in models sized up to 350 mm in diameter creates opportunities to deploy these long-life, high-efficiency LED units in applications that have been using fluorescent or incandescent sources. Available in six sizes with outer diameters of 85, 124, 154, 223, 273 and 353 mm, IHR models are available with red, white, blue or green LEDs. Additional wavelengths or sizes may be custom ordered. All IHR models are equipped with a standard diffusion optic for uniform illumination. Optional polarizing optics are available for applications requiring the suppression of glare from specular surfaces.
LDDLIGHT.com
603-732-0057, www.lddlight.com
