Metcase has created a new 19-in. mini-rackversion of its advanced TECHNOMET table-top instrument enclosures.
The new TECHNOMET cases are designed for mounting standard 19-in. subracks, chassis and front panels. Applications will include test and measurement equipment, networking and communications devices, sound and studio systems, laboratory instruments, industrial computers and control systems.
These elegant and ultra-modern enclosures combine diecast aluminum front and rear bezels, a folded case body andchassis and four snap-on cover trims to create a flush-fitting cohesive design with no visible fixing screws.
Standard 19-in. panel mounts with caged nut apertures for fixing the equipment are included in the front and rear bezels. There are three standard case sizes: 3U, 4U and 6U, all with a depth of 15.74-in. Custom depths can be supplied on request.
The rear and base panels are ventilated to aid cooling. Inside there are two subrack/chassis support rails. All case panels are fitted with M4 threaded pillars for earth connections. ABS side handles are recessed for easy portability. Molded ABS non-slip feet are also included. Prices start at $258.
Accessories include 1U to 6U (unvented and vented) 19-in. front panels and M6 caged nuts and fixing screws.
Metcase can supply TECHNOMET 19-in. enclosures fully customized. Services include: custom front panels; CNC punching, folding, milling, drilling and tapping; fixings and inserts; painting and finishing; digital printing of legends and logos.
Metcase
www.metcaseusa.com/en/Metal-Enclosures/Technomet-19-.htm
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES
