MH01-M18 Mounting Brackets from Pepperl+Fuchs
By Design World Staff | December 14, 2010
TWINSBURG, OH – Pepperl+Fuchs introduces MH01-M18 Mounting Brackets for use with the company’s ML17 series as well as all M18 cylindrical photoelectric sensor families. These mounting brackets provide an affordable means of mounting photoelectric sensors with industry-standard M18 threading in packaging, material handling and general automation applications with multi-axes alignment needs.
Pepperl_Fuchs_ML17-w-MH01-brackets
Unlike standard right angle mounting brackets that are inherently inflexible, these half-clamp style brackets allow the sensor to quickly be turned on several axes for easy adaptation to changing multi-axes alignment application needs. They fasten on a 12 mm (0.5 in.) diameter rod or bolt common to packaging and material handling equipment. Once fastened, the half-clamp can be rotated 360° around the rod or bolt to best align the sensor to satisfy the specific application requirements.
Pepperl+Fuchs
www.pepperl-fuchs.us
Filed Under: Factory automation, Automation components, Electronics • electrical, Fastening + joining • locks • latches • pins, Flanges • supports • mounts • brackets, Sensors (position + other)
molex-premo-flex
