The new CABLINE brand VS II Micro-Coaxial Cable Connector from I-PEX is an extension of the CABLINE brand VS Micro-Coaxial Cable Connector which was adopted as the VESA standard connector in 2009. The high-speed contact design is being used for data rates as high as 20 Gbps and supports the latest Thunderbolt 3 and IoT applications.
The new CABLINE-VS II Connector includes a 360° shielding cover for better EMI containment, while keeping the overall height as low as 1.3 mm max. In addition, the VESA standard connector, CABLINE-VS Receptacle can be mounted on the same PCB board layout.
The CABLINE-VS II Connector has a 0.5-mm pitch, with horizontal mating and 30 pins (a 40 pin version is coming soon). This new connector gives designers the freedom to focus on their own innovative solutions by keeping up with the latest high-speed protocols, while containing EMI issues.
For more information about this connector: I-PEX Connectors, 2305 Donley Drive, Suite 110, Austin, TX 78758 U.S.A., (512)339-IPEX(4739), Fax (512)339-4745,
https://www.i-pex.com/Products/detail/144
Filed Under: Cables + cable management, Connectors (electrical) • crimp technologies, IoT • IIoT • internet of things • Industry 4.0
