minifast® Explosion-proof Receptacles from TURCK
By Patrick Curran | March 19, 2010
Minneapolis, MN — TURCK announces new 1″-16UN and 1-1/8″-16UN minifast® explosion-proof feed-through receptacles, which install directly into standard 3/4-inch conduit entries without requiring additional conduit or poured seals. These quick-disconnect B-size (1 inch) and C-size (1-1/8 inch) receptacles expedite installation while maintaining the explosion-proof ratings of instrument housings and explosion-proof enclosures in Class I, Division 2 hazardous areas.
TURCK-minifast-explosion-proof-receptacles
Designed with high quality 316 stainless steel housings, these receptacles are fully potted and withstand 6,000 psi of pressure. To reduce wiring errors, the 7 and 8-pole B-size and 9, 10 and 12-pole C-size connectors are specially keyed in a way that ensures the connectors cannot be improperly mated. The receptacles’ connectors are compatible with TURCK’s FM approved cordsets and provide NEMA 1, 3, 4 and 6P, as well as IEC IP68 protection against liquid ingress when a mating connector is attached.
TURCK
www.turck.us
Filed Under: Connectors (electrical) • crimp technologies, Electronics • electrical, Safety systems + components
molex-premo-flex
