Misati Power Clamps Available from JW Winco
By Design World Staff | June 11, 2008
NEW BERLIN, WI — J. W. Winco, Inc. announced it is now the exclusive North American distributor for Misati, S.L. , an ISO 9001 and RoHS compliant European manufacturer of a new generation of Fastening and Transfer Press Clamps and Accessories.
These patented, smaller profile, high clamping force, super-efficient clamps are a revolutionary approach for applications in assembly, verification, handling, robotics, machining, welding, etc. Having a reduced size, these clamps achieve higher holding forces than other clamping options. The accompanying standard accessories can adapt the clamps to most all applications, such as molded, cast or machined surfaces, caustic environments, sensor requirements, etc.
Misati clamps are also designed with the ecological and business environment in mind. Smaller profile clamps use less material (producing less waste when they are discarded or recycled). These particular clamps also require less space (great space savings). Their selection of standard mounting accessories reduces design, manufacturing, assembly and set-up time of the clamps (helps achieve higher levels of efficiency and productivity). The clamps require less air to operate them (resulting in less energy consumption).
www.jwwinco.com
Filed Under: Fastening + joining, Clamps • locks • latches
Tagged With: jwwinco
