SDLM-025-070-01-01 and SDLM-025-070-01-05 direct drive linear motors from Moticont, also known as electric cylinders, have built-in encoders, and feature high acceleration, high speed, high resolution, zero backlash, and zero cogging.
These compact direct-drive linear motors with quiet linear plain bearings are just 1.00 in. (25.4 mm) in diameter and 2.75 in (69.9 mm) long. Protected inside the motor housings, are linear optical quadrature encoders which directly connects to the non rotating shaft for the greatest possible accuracy.
Select only the degree of precision application requires as the SDLM-025-070-01-01 has a resolution of 1.25 µm and the SDLM-025-070-01-05 has a resolution of 5.0 µm with a 10% savings in cost.
Each of these direct drive linear motors has a stroke length of 0.500 in. (12.7 mm) and a continuous force rating of 22.2 oz. (5.9 N) and peak force of 67.2 oz (18.7 N). Non-commutated, they feature: direct coupling of the load or stage which eliminates backlash and allows for high acceleration and deceleration. Both ends of the motor and shaft ends are drilled and tapped for easy integration into new and existing applications.
Applications include assembly, manufacturing, sorting, semiconductor handling, inspection, medical equipment and procedure tables, antenna positioning, dampers, door and valve actuators, agricultural equipment, and adjustable office furniture.
Inexpensive alternatives to hydraulic and pneumatic systems these direct-drive linear actuators or electric cylinders are also available as a complete plug-and-play linear motion systems with a matching motion controllers.
Moticont is a manufacturer of motion control products. the product line includes voice coil motors, three phase brushless motors and positioning stages and slides. Moticont is committed to exceeding the customers’ quality expectations and industry standards throughout the design, manufacturing, service and technical support phases. the modern manufacturing facility, highly controlled processes, committed staff, and extensive testing complement the product design strengths. For more information, visit moticont.com.
