Mounting keyless pulleys, gears or sprockets with a single sleeve
By Mike Santora | November 1, 2016
Coupling Tips
tsa2Asymmetric Fasteners Inc. has released a new product for mounting components onto a keyless shaft. A threaded bore in the component (pulley, gear, or sprocket) bolted with the Torksleeve A2 generates a uniform locking pressure on the shaft by turning a nut. It offers repeatable, precise positioning along with high torque transfer capability. Any component with a standard 60 deg. bore thread can be assembled with Torksleeve A2.
Torksleeve A2’s standard lone OD offers a variety of different bore sizes to accommodate different shaft diameters. The simple stainless steel single-sleeve design (PATENT PENDING) eliminates the cost of a keyway and key, and offers simple component bore machining. The sleeve can be threaded into the component from either side. This keyless fastener meets today’s challenging components mounting application demands.
Available for shaft diameters .250-.625-in. and 6– 15mm.
asymmetricfasteners.com
For more on shaft locking devices click here.
Filed Under: Coupling Tips, Collars • locking devices
Tagged With: asymmetricfasteners
PTDA onProduct Information Exchange
PTDA Transmissions: Lessons from the Pandemic past can shape the future
Shaft collars and couplings feature wide choice of standard bores
Torque transducers and test machinery use CD couplings from Zero-Max
