Multi-Passage Rotating Unions from Deublin
By Design World Staff | November 30, 2009
WAUKEGAN, IL— DEUBLIN Company introduces a new series of Multi-Passage rotating unions for the most complex and demanding fluid power applications including plastics and rubber processing, steel manufacturing, semiconductor, machine tool, aerospace and flight simulators, industrial cranes, rail transportation, de-scaling operations and more.
DEUBLIN Multi-Passage unions are modular in design and can be configured to each application. Multiple-passage unions convey virtually any liquid or gas medium (steam, water, coolant, hydraulic or cutting fluids, inert gas or vacuum). The same or different media can be conveyed to different rotating feed points within the same axis.
The requirements of each application will dictate the number of passages (from 2-12), port style (G, NPT, PT, SAE, etc), port diameter (from 1/8”-1-1/4”), flange type, housing material, and whether electrical slip rings are required. DEUBLIN incorporates a variety of sealing technologies depending on the application’s rotational speed and torque, delivered media pressure, operating temperature and other factors.
A new brochure is available (Catalog MP093US), along with an Application Worksheet that assists in the specification of the appropriate components.
DEUBLIN Company
www.deublin.com
Filed Under: Fluid power, Slip rings + rotary unions
Next steps in fluid power connections
cylinder
Small, compact cylinder boasts large preload capacity
Clippard Eclipse proportional Valve
Proportional isolation valve offers ultra fine resolution and high repeatability
Fluid power manufacturer receives environmental stewardship recognition
