Pentair Industrial announces Multi-Round Liquid Cartridge Housings, a versatile solution for commercial and industrial filtration requirements. Multi-Round Liquid Cartridge Housings offer an exceptional 11 to 205 cartridge capacity, and accept 20-, 30- or 40-inch filter cartridges, delivering flow rates from 120 to 4100 GPM. These capacity options ensure Multi-Round Liquid Cartridge Housings provide optimum particle retention while delivering the flexibility to handle a broad range of flow rates and applications.
Multi-Round Liquid Cartridge Housings deliver a 150 PSI pressure rating and accept double open-end cartridges (DOE) or 222 style cartridges with closed top caps. They additionally provide several housing options, including a duplexing housing for continual flow during maintenance, as well as housings with higher pressure ratings and different connection sizes and types. Users can add ASME Code U stamp as an option.
For durable, long-lasting operation, Multi-Round Liquid Cartridge Housings feature carbon and stainless steel construction options, paired with 316 stainless steel center guide posts, cup and spring assemblies, as well as heavy-duty support legs. A two-part epoxy finish is also offered on carbon steel models, and all Multi-Round Liquid Cartridge Housings feature bearing-assisted davit assemblies, Buna-N® lid seals and plated swing bolts and eye nuts. Differential, drain and vent ports are also available.
Filed Under: FLUID POWER
