Garden City Park, New York‚— Quality Bearings & Components announces a new line of high carbon steel needle bearing sealed cam followers, identified as the BBXCAM-CN… Series. They feature hardened and ground outer race and low-carbon alloy steel hardened studs and inner races. They are both hex-head or slotted-head type. They are available in nominal I.D.’s ranging from 1/2″ to 4″. They may be lubricated through the head end only and have a clamping torque based on dry threads. Quotes plus online orders are available at the new QBC eStore. This quality design ensures reduced friction, quiet operating ability and increased durability.
QBC has in stock: miniature bearings, plastic bearings, rod end bearings, spherical bearings, pillow blocks, sintered bronze bushings, radial ball bearings, thrust bearings & washers, sleeve bearings, needle bearings, inner races, roller clutches, guide wheels & rail systems, linear ball bearings, inner and outer ring spacers and shafting. QBC stocks both inch and metric sizes. New to the Web site is our eStore which allows you to check price and availability, place an order or request a quote anytime. QBC also provides custom-made bearings and shafting to the customer print. We also offer on-site relubing of bearings in a certified class 1000 clean room.
Filed Under: LINEAR MOTION, Motion control • motor controls
