Ann Arbor, Michigan – Nematron Corporation announces the launch of the new ePC-Series of Industrial Computers. There are currently three sizes, 15”,17”, and 19” in this series with more additions to follow. All areavailable with 5-wire Analog Resistive touchscreens and NEMA sealedpanel mount front panels. Their ultra-thin size and very thin panel
mounted depth of less than 3.0” (76.2mm) make them ideal for
installation in harsh environments, especially hazardous locations.
The
ePC-Series computers include 15” (ePC1500) XGA, 17” (ePC1700) SXGA, and
a 19” (ePC1900) SXGA LCD version. All versions are standard with
100-240 VAC input power supplies, have NEMA 4/4x/12 panel mountable
front panels, and are less than 3.0” deep when panel mounted. Stainless
Steel front panels, Solid State non-rotating hard drives, and 24 Volt
DC input power are available options for all three. The included
CompactFlash socket and extensive I/O eliminate the need for bulky
expansion slots and unreliable rotating CD-ROMs and floppies. I/O ports
included on every unit include; two 10/100/1000 Ethernet , one
RS-422/485, two RS-232, four USB 2.0, PS/2, and even an external Video
connection that supports dual display with extended desktop. With
options up to an Intel Core Duo 2.0 GHz processor and 2 GB DRAM the
ePC-Series provides enough processing power to run the most complex HMI
and SCADA applications. To top this all off the SATA hard drive can be
easily removed without any cable connections.
All
sizes of the ePC-Series will have UL and cUL 508 as well as Class I
Division 2, RoHS, and European CE approvals, making system integration
a breeze for virtually any application and/or location.
www.nematron.com
.:Design World:.
Filed Under: Industrial computers, ELECTRONICS • ELECTRICAL
