The release of Continental’s expanded line of Proportional Pressure Relief Valves delivers smarter, more energy efficient, simplified and compact hydraulics systems.
“Every hydraulic system needs to have pressure control,” said Vonn Bonnema, Continental Director of Sales. “Now, we can help your customers control force and pressure elegantly.”
Some features of the VER03M:
• It has an extremely wide dynamic range of pressures with great repeatability. This high-performance, direct operated valve flows up to 1 gpm and is the perfect pilot control signal solution
• It supports higher flow needs, to 8 gpm
• The VER*SP supports even greater flow needs up to 132 gpm. It also includes a manually adjustable, built-in manual relief valve to limit pressure and ensure safety
• The VER family of valves includes pressure ranges up to 5000 psi, is interchangeable with industry standard products currently in use, and has the option of integrating on-board digital electronics.
Continental Hydraulics
Filed Under: Mobile Hydraulic Tips, Electronics • electrical, Hydraulic equipment + components, Safety systems + components
